1998-05-21 | Added bare bsp from Chris Johns <cjohns@plessey.com.au>. | Joel Sherrill | 1 | -0/+51 | |
1998-05-21 | Per patch from Ralf Corsepius removed redundant lines. | Joel Sherrill | 1 | -23/+0 | |
1998-05-21 | Removed undesirable space in TARGET_ARCH assignment line. | Joel Sherrill | 1 | -9/+4 | |
Cleaned up command line macro definitions. Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | |||||
1998-05-21 | Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | Joel Sherrill | 1 | -4/+0 | |
1998-05-20 | Some patches in place from Brian Stevens which help the Solaris port | Joel Sherrill | 1 | -7/+10 | |
build. It does not link successfully for him. It does not compile for me locally. | |||||
1998-05-20 | Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This | Joel Sherrill | 1 | -1/+6 | |
lets the makefile work in both cases. | |||||
1998-05-18 | Added much stuff formerly in multiple compiler files. | Joel Sherrill | 1 | -0/+27 | |
1998-05-18 | Added conditional around TARGET_ARCH to prevent accidental overrides. | Joel Sherrill | 1 | -0/+2 | |
1998-05-18 | Switched to using shared gcc-target-default.cfg. | Joel Sherrill | 3 | -12/+10 | |
1998-05-04 | Modified objcopy to remove extra sections. | Joel Sherrill | 1 | -3/+6 | |
Modified gcc 2.8 style link rule to provide start address correctly. | |||||
1998-04-30 | Changed default target architecture name | Joel Sherrill | 1 | -1/+1 | |
1998-04-30 | Modified objcopy invocation to ignore more sections. | Joel Sherrill | 1 | -3/+7 | |
1998-04-27 | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>. | Joel Sherrill | 1 | -17/+31 | |
1998-04-27 | Fixes from Ralf Corsepius: | Joel Sherrill | 4 | -45/+21 | |
* Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg files to make/custom/posix.cfg, Removed references to stdc++ from *posix.cfg files (rtems doesn't use/need libstdc++) NOTE: Building Posix-BSPs should now work again for native compilation with gcc, i..e. linux using primary compiler and primary libc. All Posix-BSP configurations that don't use gcc as primary compiler or don't use the primary libc don't work, e.g. solaris, linux w/ egcs as secondary compiler won't be built correctly. | |||||
1998-04-27 | Removed forced enable of POSIX API. Now follow configuration flag. | Joel Sherrill | 1 | -3/+0 | |
1998-04-15 | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 26 | -124/+0 | |
eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | |||||
1998-04-14 | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1 | -1/+2 | |
gcc-target-default.cfg | |||||
1998-04-14 | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 3 | -66/+230 | |
1998-04-14 | Stack checker on | Joel Sherrill | 1 | -6/+1 | |
1998-04-14 | Updates from PPC refresh | Joel Sherrill | 1 | -3/+33 | |
1998-04-14 | new file | Joel Sherrill | 1 | -0/+122 | |
1998-04-06 | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 22 | -113/+1 | |
1998-04-06 | Changed CPU model to mcpu32. | Joel Sherrill | 1 | -1/+1 | |
1998-03-30 | Made the POSIX API option follow the configure line. | Joel Sherrill | 1 | -3/+1 | |
1998-03-30 | Made the HAS_POSIX_API follow the configure line option. | Joel Sherrill | 1 | -5/+0 | |
1998-03-30 | Made the C++ option follow the configure option. | Joel Sherrill | 1 | -9/+0 | |
1998-03-30 | Made HAS_POSIX_API have a "no" definition when it is not enabled. | Joel Sherrill | 1 | -0/+2 | |
1998-03-30 | Made C++ follow the configure option. | Joel Sherrill | 1 | -4/+0 | |
1998-03-24 | Changed RTEMS cpu to hppa1.1. | Joel Sherrill | 1 | -2/+1 | |
1998-03-24 | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1 | -0/+1 | |
the CPU family name constants. | |||||
1998-03-23 | renamed ppc to powerpc | Joel Sherrill | 1 | -1/+1 | |
1998-03-23 | Update from Eric Norum: | Joel Sherrill | 1 | -12/+3 | |
Here are some patches to the gen68360 BSP. The improvements include: Boot prom run-time selection of DRAM size (1/4/16 Mbytes) Full 32-bit ethernet address obtained from boot prom. Updated README. | |||||
1998-03-20 | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1 | -11/+2 | |
I've included a version of make/custom/gen68360.cfg that works with this. Note that I've removed the option of using `-m68020 -msoft-float -mno-bitfield' as an alternative to using `-mcpu32'. The alternative won't work with the new system (since it predefines __mc68020__ and not __mcpu32__), and didn't really work before anyway (since the newlib that gets linked was built with `-m68020 -msoft-float' and so could contain bitfield operators). | |||||
1998-03-20 | New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+108 | |
1998-02-19 | Patch from Eric Norum: | Joel Sherrill | 1 | -5/+0 | |
While trying to work through this problem I decided that the build-time selection of the console I/O operation (polling or interrupt) was too clumsy. Here's a patch that allows run-time (actually init-time) selection of the console I/O mode. It also shows the need for another `flags' or `options' field in the rtems_driver_address_table structure... | |||||
1998-02-18 | Went back to polled console. | Joel Sherrill | 1 | -1/+1 | |
1998-02-04 | Cleaned up the definition of CONSOLE_USE_POLLED and CONSOLE_USE_INTERRUPTS. | Joel Sherrill | 1 | -9/+9 | |
1998-01-27 | not submitted | Joel Sherrill | 1 | -106/+0 | |
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 1 | -1/+11 | |
1998-01-20 | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 33 | -0/+2667 | |
