* | Use $(NM) -g -n instead of $(NM) -ng. | Ralf Corsepius | 2007-01-18 | 5 | -5/+5 |
* | Fix cvs id. | Ralf Corsepius | 2007-01-18 | 2 | -2/+2 |
* | Misc cleanups. | Ralf Corsepius | 2007-01-18 | 23 | -65/+54 |
* | Add comment on CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 3 | -3/+3 |
* | Remove obsolete comments. | Ralf Corsepius | 2007-01-18 | 2 | -6/+0 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 36 | -36/+36 |
| | | | | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg, custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg, custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg, custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg, custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 20 | -27/+27 |
* | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 2007-01-18 | 46 | -92/+46 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -3/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 5 | -7/+3 |
* | Remove CXXFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 3 | -3/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+0 |
* | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 2007-01-18 | 6 | -6/+5 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 9 | -9/+0 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 1 | -2/+1 |
| | | | | * custom/h8sim.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 13 | -18/+16 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 47 | -55/+55 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 1 | -4/+1 |
| | | | | | * custom/csb336.cfg, custom/edb7312.cfg, custom/gba.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 2007-01-18 | 3 | -7/+3 |
* | CFLAGS_OPTIMIZE_V = -O2 | Ralf Corsepius | 2007-01-17 | 3 | -3/+3 |
* | CFLAGS_OPTIMIZE_V = -O0 | Ralf Corsepius | 2007-01-17 | 2 | -9/+3 |
* | CFLAGS_OPTIMIZE_V = -O2 | Ralf Corsepius | 2007-01-17 | 4 | -7/+7 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 1 | -6/+0 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 69 | -250/+67 |
* | Remove hard-code compiler flags. | Ralf Corsepius | 2006-11-14 | 1 | -2/+2 |
* | Remove ASFLAGS, CPU_ASFLAGS (Unused) | Ralf Corsepius | 2006-11-14 | 4 | -8/+0 |
* | 2006-10-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-23 | 1 | -0/+41 |
| | | | | * custom/eZKit533.cfg: New file. | ||||
* | 2006-09-08 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2006-09-08 | 1 | -1/+1 |
| | | | | | | | PR 1150/bsps * custom/mvme5500.cfg: This is a follow-up of the PR846 due to the fact that gcc (4.0.2) implicitely uses the vector engine for optimization; -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec is better. | ||||
* | added missing config file brs5l.cfg | Thomas Doerfler | 2006-08-11 | 1 | -0/+15 |
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 1 | -0/+47 |
| | | | | | * Makefile.am: New port to Altera NIOS II. * custom/nios2_iss.cfg: New file. | ||||
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 1 | -1/+1 |
* | Remote gdb works well, so include debugging symbols. | Eric Norum | 2006-06-20 | 1 | -1/+1 |
* | B.Robinson MIPS patch | Greg Menke | 2006-06-08 | 2 | -2/+2 |
* | Remove non-longer-appropriate comment. | Eric Norum | 2006-05-15 | 1 | -1/+0 |
* | Keep the frame pointer since its presence makes various diagnostic tools | Eric Norum | 2006-04-10 | 1 | -1/+1 |
| | | | | much more useful. | ||||
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 3 | -0/+107 |
| | | | | | * custom/hurricane.cfg, custom/rbtx4925.cfg, custom/rbtx4938.cfg: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | ||||
* | Remove (abandoned). | Ralf Corsepius | 2006-03-16 | 3 | -126/+0 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 4 | -9/+52 |
* | New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>). | Ralf Corsepius | 2006-01-01 | 3 | -0/+70 |
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 2 | -20/+20 |
| | | | | * custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj. | ||||
* | Use .srec for files containing SRECs. | Ralf Corsepius | 2005-11-22 | 9 | -20/+20 |
* | Replace .coff with .elf. | Ralf Corsepius | 2005-11-22 | 2 | -6/+6 |
* | Replace .gxb with .elf. | Ralf Corsepius | 2005-11-22 | 1 | -2/+2 |
* | 2005-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-11-04 | 1 | -1/+1 |
| | | | | | * custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use -mcpu=750 instead. | ||||
* | Remove obsolete vars. | Ralf Corsepius | 2005-09-18 | 1 | -34/+0 |
* | Remove (abandoned). | Ralf Corsepius | 2005-09-18 | 1 | -22/+0 |
* | 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-18 | 1 | -6/+2 |
| | | | | | * custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus). | ||||
* | 2005-09-12 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Joel Sherrill | 2005-09-12 | 2 | -0/+26 |
| | | | | | PR 822/bsps * custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files. | ||||
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 1 | -0/+86 |
| | | | | * custom/av5282.cfg: New file. | ||||
* | 2005-06-17 Markku Puro <markku.puro@kopteri.net> | Joel Sherrill | 2005-06-17 | 1 | -0/+60 |
| | | | | | * Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file. |
