* | 2005-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-11-04 | 1 | -1/+1 |
| | | | | | * custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use -mcpu=750 instead. | ||||
* | Remove obsolete vars. | Ralf Corsepius | 2005-09-18 | 1 | -34/+0 |
* | Remove (abandoned). | Ralf Corsepius | 2005-09-18 | 1 | -22/+0 |
* | 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-18 | 1 | -6/+2 |
| | | | | | * custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus). | ||||
* | 2005-09-12 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Joel Sherrill | 2005-09-12 | 2 | -0/+26 |
| | | | | | PR 822/bsps * custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files. | ||||
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 1 | -0/+86 |
| | | | | * custom/av5282.cfg: New file. | ||||
* | 2005-06-17 Markku Puro <markku.puro@kopteri.net> | Joel Sherrill | 2005-06-17 | 1 | -0/+60 |
| | | | | | * Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 1 | -0/+51 |
| | | | | * custom/mcf5235.cfg: New file. | ||||
* | 2005-06-01 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2005-06-02 | 1 | -8/+11 |
| | | | | * custom/gp32.cfg: Add make-cxx-exe. | ||||
* | Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | Ralf Corsepius | 2005-05-27 | 6 | -7/+0 |
* | 2005-05-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-02 | 1 | -40/+0 |
| | | | | | * Makefile.am: Remove dmv177 and ppcn_60x. * custom/dmv177.cfg: Removed. | ||||
* | 2005-05-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-30 | 1 | -36/+0 |
| | | | | * custom/ppcn_60x.cfg: Remove (Gone from libbsp). | ||||
* | 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-04-28 | 1 | -0/+36 |
| | | | | | * Makefile.am: Initial release of ep1a bsp * custom/ep1a.cfg: New file. | ||||
* | 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-04-28 | 1 | -2/+2 |
| | | | | | * custom/score603e.cfg: Update score603e to new exception model NOTE: These modifications have not been tested on hardware. | ||||
* | 2005-03-11 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2005-03-11 | 1 | -50/+0 |
| | | | | * custom/vegaplus.cfg: Removed. | ||||
* | 2005-03-11 Philippe Simons <loki_666@fastmail.fm> | Jay Monkman | 2005-03-11 | 1 | -0/+39 |
| | | | | * custom/gp32.cfg: New file. | ||||
* | 2005-03-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-03-03 | 3 | -21/+3 |
| | | | | | | * custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI. * custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V. Remove -Wa,-m7450. | ||||
* | 2005-02-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-25 | 2 | -51/+1 |
| | | | | | * custom/jmr3904.cfg: arm_bare_bsp obsoleted. * custom/arm_bare_bsp.cfg: Removed. | ||||
* | 2005-02-24 Jay Monkman | Jay Monkman | 2005-02-25 | 1 | -9/+2 |
| | | | | * custom/csb337.cfg: Cleanup. | ||||
* | 2005-02-24 Jay Monkman | Jay Monkman | 2005-02-25 | 1 | -0/+38 |
| | | | | * custom/csb350.cfg: New BSP. | ||||
* | Put -m5200 back in link-edit commands until proper versions of gcc (which take | Eric Norum | 2005-02-08 | 1 | -2/+2 |
| | | | | -m528x as an order to load the -m5200 multilib variants) are widely available. | ||||
* | 2005-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-05 | 1 | -57/+9 |
| | | | | * custom/uC5282.cfg: Cleanup. | ||||
* | New BSP. | Eric Norum | 2005-01-28 | 1 | -0/+86 |
* | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-20 | 11 | -12/+24 |
| | | | | | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg, custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg, custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg, custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for gcc 4.x. Hopefully they are still OK for gcc 3.3.5. | ||||
* | 2004-11-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-23 | 1 | -50/+0 |
| | | | | | * Makefile.am: Remove eth_comm. * custom/eth_comm.cfg: Removed. | ||||
* | 2004-11-22 Jennifer Averett <jennifer@OARcorp.com> | Jennifer Averett | 2004-11-22 | 1 | -2/+2 |
| | | | | | PR 581/bsps * custom/psim.cfg: Convert PSIM to new exception model. | ||||
* | 2004-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-17 | 1 | -0/+13 |
| | | | | * custom/mvme2100.cfg: Add make-cxx-exe rule. | ||||
* | 2004-11-10 Richard Campbell <richard.campbell@oarcorp.com> | Joel Sherrill | 2004-11-10 | 1 | -0/+47 |
| | | | | | * Makefile.am: Add MVME2100 BSP. * custom/mvme2100.cfg: New file. | ||||
* | 2004-11-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-05 | 2 | -4/+4 |
| | | | | | | * custom/csb336.cfg, custom/csb337.cfg: RTEMS_CPU must match an architecture name for RTEMS. Since this was used as the -mcpu argument to GCC, that also had to be changed. | ||||
* | Add -Wa,-m7450 to CPU_CFLAGS until gcc/gas get their acts together. | Eric Norum | 2004-10-27 | 1 | -1/+1 |
* | Add MVME5500 BSP. | Eric Norum | 2004-10-20 | 1 | -0/+48 |
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 2 | -8/+26 |
| | | | | * custom/c3xsim.cfg, custom/c4xsim.cfg: Expand files. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 4 | -116/+1 |
| | | | | | * custom/h8sim.cfg: i960 obsoleted. * custom/cvme961.cfg, custom/i960sim.cfg, custom/rxgen960.cfg: Removed. | ||||
* | 2004-08-03 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2004-08-03 | 1 | -0/+40 |
| | | | | * custom/csb360.cfg: New file. | ||||
* | 2004-07-15 Jay Monkman | Jay Monkman | 2004-07-15 | 2 | -0/+80 |
| | | | | * custom/csb336.cfg, custom/csb337.cfg: New files. | ||||
* | 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-13 | 2 | -3/+1 |
| | | | | | | * custom/FreeBSD-posix.cfg: Remove LIBC_DEFINES (Meaningless with FreeBSD and now unused). * custom/Solaris-posix.cfg: Add -D__EXTENSIONS__ to CPU_CFLAGS. | ||||
* | 2004-04-12 David Querbach <querbach@realtime.bc.ca> | Joel Sherrill | 2004-04-12 | 1 | -0/+49 |
| | | | | | * custom/ss555.cfg: New file. | ||||
* | 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-09 | 1 | -4/+0 |
| | | | | | * make/Cygwin-posix.cfg: Remove DEFINES + LIBC_DEFINES (Meaningless with Cygwin and now unused). | ||||
* | 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-09 | 1 | -3/+1 |
| | | | | * make/Linux-posix.cfg: Merge LIBC_DEFINES into CPU_CFLAGS. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2004-03-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-03-05 | 1 | -7/+1 |
| | | | | | * custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x support. | ||||
* | 2004-02-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-26 | 1 | -1/+2 |
| | | | | | | PR 570/bsps * custom/mvme2307.cfg: Do not use -msdata=eabi since it breaks the linking of the vectors. | ||||
* | 2004-02-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-05 | 3 | -0/+132 |
| | | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Re-added these -- copied from the 4.6 branch. | ||||
* | 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-04 | 1 | -1/+1 |
| | | | | | PR 553/bsps * custom/mrm332.cfg: Comment out objdump. | ||||
* | 2004-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-20 | 1 | -1/+4 |
| | | | | | | PR 553/bsps * custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a comment. | ||||
* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 2 | -76/+0 |
| | | | | | | Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any users of these boards so we are removing them. * custom/efi332.cfg, custom/efi68k.cfg: Removed. | ||||
* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 3 | -132/+0 |
| | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Removed. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -23/+0 |
| | | | | | * custom/Makefile.am: Remove. * Makefile.am: Merge-in former custom/Makefile.am | ||||
* | 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-24 | 2 | -14/+0 |
| | | | | | * custom/HPUX9-posix.cfg: Remove INLINE, INLINE_UPCASE. * custom/default.cfg: Remove INLINE,INLINE_UPCASE. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 1 | -92/+0 |
| | | | | * custom/simhppa.cfg: Removed. |
