PR 368/filesystems
* custom/mbx821_002.cfg, custom/mbx821_002b.cfg: New files included
with this PR for alias BSPs.
PR 356/bsps
* custom/mvme2307.cfg: This patch makes RTEMS/PowerPC eabi compliant.
Enable EABI by adding -meabi -msdata=eabi CFLAGS.
AMD a29k obsolete.
* custom/portsw.cfg: Removed.
* custom/m2m332.cfg: Fix path to linkcmds_ROM.
* custom/Cygwin-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/FreeBSD-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/HPUX9-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/Linux-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -D_BSD_SOURCE to CPU_CFLAGS.
* custom/Solaris-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -Dsolaris2 to CPU_CFLAGS.
Remove -D__EXTENSIONS__.
* custom/posix.cfg: Remove comment referring to host.cfg.
* custom/default.cfg: Pickup target.cfg from BSP directory.
* custom/mtx603e.cfg: New file.
* custom/Cygwin-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Linux-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Solaris-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/FreeBSD-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/HPUX9-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/edb7312.cfg: New file.
* custom/default.cfg: Remove RTEMS_BSP_SPECS. Remove reference to
obsolete Makefile.
* leaf.cfg: Various changes to LIBVARIANT processing.
* main.cfg: Ditto.
* custom/Cygwin-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* custom/HPUX9-posix.cfg: Ditto.
* custom/Linux-posix.cfg: Ditto.
* custom/armulator.cfg: Remove reference to PowerPC arguments.
* custom/posix.cfg: Don't include host.cfg.
* custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc.
* orp.cfg: Bender BSP renamed to OpenRisc Reference Platform or ORP.
* custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg,
custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* custom/or32sim.cfg: New file added as part of merge from
OpenCores repository.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* custom/gen68360.cfg: Remove make-target-options.
* eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg,
mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* custom/mvme136.cfg: Per PR260 removed make-target-options.
* custom/vegaplus.cfg: Generate the Mapfile into $(ARCH) so it
will disappear when make clean is performed.
* custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg: Updated
to use gcc 3.1 arguments.
* custom/p4650.cfg: Update arguments to gcc3.
* custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch
to gcc 3.1 arguments.
* custom/dmv177.cfg: Use -mcpu=603e.
* custom/ppcn_60x.cfg: Use -mcpu=603e.
* custom/psim.cfg: Use -mcpu=603e.
* custom/score603e.cfg: Use -mcpu=603e.
* custom/ts_386ex.cfg: Remove obsolete comments.
* custom/rxgen960.cfg: Remove obsolete comments.
* custom/cvme961.cfg: Remove obsolete comments.
* custom/jmr3904.cfg, custom/p4650.cfg: Add comments for gcc 3.1
compatable arguments.
* custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/eth_comm.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS.
* custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS.
* custom/mbx8xx.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS.
* custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS.
* custom/mpc8260ads.cfg: Remove make-target-options.
Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS.
* custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/gen405.cfg: Remove -D__powerpc__.
* custom/erc32nfp.cfg: Remove CPU_U32_FIX.
* custom/erc32.cfg: Ditto.
* custom/leon2.cfg: Ditto.
* custom/erc32.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB.
* custom/erc32nfp.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB.
* custom/leon2.cfg: Remove NO_TABLE_MOVE.
* Templates/Makefile.am: Remove AUTOMAKE_OPTIONS.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS.
* custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272
support.
* custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* custom/Cygwin-posix.cfg: Remove -DMALLOC_PROVIDED.
* custom/FreeBSD-posix.cfg: Ditto.
* custom/Solaris-posix.cfg: Ditto.
* custom/erc32.cfg: Remove erc32nfp support, GCC272.
* custom/erc32nfp.cfg: Merge in portions from erc32.cfg.
* custom/armulator.cfg: Remove make-target-options.
* custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE
(now in erc32/configure.ac).
* custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS,
SIMSPARC_FAST_IDLE (now in leon2/configure.ac).
Remove CONSOLE_USE_POLLED (Unused).
* custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE,
CD2401_USE_TERMIOS (now in mvme167/configure.ac).
* custom/mvme162.cfg: Remove references to mvme162lx.
Abandon gcc272. Remove make-target-options.
* custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/efi332.cfg: Remove make-target-options.
* custom/idp.cfg: Ditto.
* custom/jmr3904.cfg: Ditto.
This was tracked as PR39.
* custom/ods68302.cfg: Eliminated required definition of macros in this
file for the BSP to compile. The ROM and ROM address and size settings
are now linker script items.
* custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/papyrus.cfg: Removed.
* custom/Makefile.am, custom/helas403.cfg: Removed reference to above.
* custom/mvme2307.cfg: Reflect changes to motorola_powerpc/configure.ac.
* custom/mcp750.cfg: Ditto.
* custom/dmv177.cfg: Reflect changes to dmv177/configure.ac.
* custom/ppcn_60x.cfg: Refect changes to ppcn_60x/configure.ac.
* custom/psim.cfg: Refect changes to psim/configure.ac.
* custom/score603e.cfg: Reflect changes to score603e/configure.ac,
remove SCORE603E_GENERATION.
* custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac.
* custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac.
* custom/mbx860_005b.cfg: Ditto.
* custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* custom/gensh1.cfg: remove make-target-options.
* custom/gensh2.cfg: remove make-target-options.
* custom/dmv152: Remove USE_CONSOLE_A, Remove USE_CONSOLE_B,
remove make-target-options, remove BSP_CPPFLAGS.
