* | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-14 | 1 | -1/+1 |
| | | | | * custom/gen83xx.cfg: Remove -funit-at-a-time. | ||||
* | 2009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-27 | 2 | -3/+2 |
| | | | | * custom/leon2.cfg, custom/leon3.cfg: Fix typo. | ||||
* | 2009-06-04 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2009-06-04 | 1 | -0/+20 |
| | | | | | * Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file. | ||||
* | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-28 | 1 | -0/+10 |
| | | | | * custom/csb637.cfg: New file. | ||||
* | added missing files | Thomas Doerfler | 2009-02-27 | 3 | -0/+46 |
* | * README: Added NCS. | Thomas Doerfler | 2009-02-27 | 1 | -15/+8 |
| | | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | ||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 1 | -0/+18 |
| | | | | * custom/simsh2e.cfg: New file. | ||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 1 | -2/+1 |
| | | | | | PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF. | ||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-17 | 1 | -0/+2 |
| | | | | * custom/uC5282.cfg: Add cvs Id. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 1 | -1/+1 |
| | | | | * custom/h8sxsim.cfg: Small H8SX should be optimized for size. | ||||
* | Remove. | Ralf Corsepius | 2009-02-06 | 1 | -19/+0 |
* | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-05 | 1 | -13/+0 |
| | | | | * custom/pck6.cfg: Remove. | ||||
* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 1 | -0/+30 |
| | | | | | * Makefile.am: Add Lattice Mico32 support. * custom/lm32_evr.cfg: New file. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 1 | -0/+20 |
| | | | | * custom/avrtest.cfg: New file. | ||||
* | 2008-11-20 Daron Chabot <daronchabot@gmail.com> | Joel Sherrill | 2008-11-20 | 1 | -1/+0 |
| | | | | | | PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target. | ||||
* | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-14 | 1 | -0/+21 |
| | | | | | * Makefile.am: Add h8sxsim BSP variant. * custom/h8sxsim.cfg: New file. | ||||
* | Added -msoft-float and removed -funit-at-a-time in CPU_CFLAGS | Thomas Doerfler | 2008-10-10 | 1 | -1/+1 |
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -0/+21 |
| | | | | * custom/m32rsim.cfg: New file. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -0/+22 |
| | | | | * custom/m32csim.cfg: New file. | ||||
* | Remove -Dvirtex. | Ralf Corsepius | 2008-10-02 | 1 | -1/+1 |
* | Remove RTEMS_TQM_MODEL. | Ralf Corsepius | 2008-10-02 | 3 | -3/+1 |
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 3 | -5/+2 |
* | Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | 2008-10-02 | 1 | -2/+0 |
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 1 | -1/+1 |
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 5 | -6/+1 |
* | Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | Ralf Corsepius | 2008-10-02 | 4 | -8/+1 |
* | 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-01 | 1 | -1/+1 |
| | | | | * custom/erc32.cfg: Revert accidental commit. | ||||
* | Back out parts of yesterdays changes. | Ralf Corsepius | 2008-10-01 | 17 | -7/+22 |
* | 2008-10-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 2 | -3/+2 |
| | | | | * custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags. | ||||
* | 2008-09-30 Jennifer Averett <jennifer.averett@oarcorp.com> | Joel Sherrill | 2008-09-30 | 1 | -1/+1 |
| | | | | | * custom/score603e.cfg: Modifications required to run on hardware. Some cleanup. | ||||
* | Eliminate RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | 2008-09-30 | 1 | -1/+0 |
* | Eliminate RTEMS_TQM_MODEL (Unused). | Ralf Corsepius | 2008-09-30 | 3 | -3/+1 |
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-09-30 | 15 | -19/+5 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 3 | -9/+4 |
| | | | | | * custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use RTEMS_BSP_FAMILY. | ||||
* | Remove Author notice. | Ralf Corsepius | 2008-09-29 | 2 | -4/+0 |
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 4 | -43/+11 |
| | | | | | | | | | * Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4. * custom/simsh1.cfg, custom/simsh2.cfg: New files. * custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed. | ||||
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 1 | -23/+0 |
| | | | | * custom/bf537skyeye.cfg: Removed. | ||||
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 3 | -1/+26 |
| | | | | | | * custom/bf537Stamp.cfg, custom/erc32.cfg: Add skyeye alias for bf537stamp. * custom/bf537skyeye.cfg: New file. | ||||
* | 2008-09-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-23 | 1 | -1/+3 |
| | | | | | * custom/lpc2478.cfg: Comment out use of U-Boot specific mkimage since we do not reliably know it is installed. | ||||
* | added BSP for ARM LPC24xx | Thomas Doerfler | 2008-09-22 | 1 | -0/+24 |
* | 2008-09-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-19 | 5 | -6/+4 |
| | | | | | | * custom/ep1a.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/psim.cfg, custom/score603e.cfg: Eliminate vestiges of mpc603e define. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-18 | 12 | -36/+0 |
| | | | | | | | | | * compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg, custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg, custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate START_BASE and START_FILE. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-18 | 1 | -13/+3 |
| | | | | | PR 1314/bsps * custom/mvme3100.cfg: Remove old stuff. | ||||
* | 2008-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-09 | 9 | -49/+14 |
| | | | | | | | | | * leaf.cfg, compilers/gcc-target-default.cfg, custom/bf537Stamp.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg, custom/mbx8xx.cfg, custom/mpc55xx.cfg, custom/nds.cfg, custom/pc386.cfg, custom/tqm8xx.cfg: Remove use of AM_LDFLAGS. Ensure LDFLAGS works all the time. Clean up BSPs which defined their own make-exe rules inappropriately. | ||||
* | added BSP for tqm8xx based boards | Thomas Doerfler | 2008-09-08 | 3 | -0/+49 |
* | More CPU_CFLAGS: -meabi -msdata -fno-common | Thomas Doerfler | 2008-09-03 | 1 | -1/+3 |
* | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-08-15 | 1 | -0/+33 |
| | | | | * custom/bf537Stamp.cfg: New file. | ||||
* | updated gen83xx BSP | Thomas Doerfler | 2008-07-14 | 4 | -2/+56 |
| | | | | | updated haleakala BSP added MPC55xx BSP | ||||
* | added haleakala BSP contributed by Michael Hamel | Thomas Doerfler | 2008-07-14 | 1 | -0/+30 |
* | added BSP for mcf548x | Thomas Doerfler | 2008-07-11 | 2 | -0/+58 |
