* | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-01-31 | 1 | -0/+2 |
| | | | | * custom/ss555.cfg: Add CVS Id. | ||||
* | 2008-01-09 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2008-01-09 | 1 | -0/+8 |
| | | | | * custom/mvme3100.cfg: Add make-cxx-exe rule. | ||||
* | 2007-12-17 Chris Johns <chrisj@rtems.org> | Chris Johns | 2007-12-17 | 3 | -37/+75 |
| | | | | | | * custom/mcf5235.cfg, custom/mrm332.cfg, custom/pc386.cfg: Split the make-exe and make-cxx-exe into bsp-link-c, bsp-link-cxx and bsp-post-link make macros. This allow external autotools support. | ||||
* | 2007-12-14 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-12-14 | 1 | -0/+44 |
| | | | | * custom/mvme3100.cfg: Added; new BSP. | ||||
* | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-28 | 1 | -1/+1 |
| | | | | * custom/mvme5500.cfg: Fix typo. | ||||
* | 2007-11-27 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2007-11-27 | 1 | -1/+1 |
| | | | | | * custom/mvme5500.cfg: Add compiler arguments sine without them, the BSP has issues. | ||||
* | 2007-11-03 Ray Xu <rayx.cn@gmail.com> | Joel Sherrill | 2007-11-06 | 1 | -0/+20 |
| | | | | | * custom/rtl22xx_t.cfg: New file, rtl22xx_t is a new bsp compiled with THUMB enabled | ||||
* | fixed typo | Thomas Doerfler | 2007-08-10 | 1 | -1/+1 |
* | added BSP hsc_cm01 | Thomas Doerfler | 2007-08-10 | 2 | -1/+17 |
* | 2007-08-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-06 | 1 | -4/+5 |
| | | | | | | * custom/icecube.cfg: Rename EP5200 to IceCube since that is the nickname for the Freescale evaluation board it is based upon. BSP was tested on a Freescale MPC5200LITE. | ||||
* | 2007-08-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-05 | 1 | -2/+2 |
| | | | | * custom/mcf5235.cfg: Remove bogus -m5200 from linker calls. | ||||
| | | | | | * custom/av5282.cfg: Remove bogus -qnolinkcmds, -m5200 from linker calls. | ||||
* | 2007-08-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-05 | 1 | -1/+1 |
| | | | | * custom/gen83xx.cfg: Use -O2. | ||||
* | 2007-07-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-28 | 1 | -1/+1 |
| | | | | * custom/Linux-posix.cfg: Use -O2. | ||||
| | | | | * custom/rbtx4938.cfg: Add missing -O2. | ||||
| | | | | * custom/rtl22xx.cfg: Adjust indentation. | ||||
| | | | | * custom/virtex.cfg: Use -O2. | ||||
* | 2007-07-24 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-07-24 | 1 | -1/+1 |
| | | | | | | * custom/Linux-posix.cfg: Make Linux link with just a C main -- avoid using C++ ctor trick. An RTEMS C++ application running on this BSP may have initialization order issues to address. | ||||
| | | | | * custom/Linux-posix.cfg: Linux BSP must be linked with C++ compiler. | ||||
* | 2007-07-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-07-11 | 1 | -0/+8 |
| | | | | * custom/gen83xx.cfg: Add make-cxx-exe rule. | ||||
* | compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵ | Thomas Doerfler | 2007-07-10 | 2 | -0/+55 |
| | | | | many different versions of new exception handling code to shared sources. | ||||
* | added virtex configuration | Thomas Doerfler | 2007-07-04 | 1 | -0/+57 |
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 1 | -1/+1 |
| | | | | | | | * custom/Linux-posix.cfg: Merge patch from Till Straumann which would work except gcc core dumps with an ICE when may_alias is used in this code. I filed a GCC PR and reduced optimization to -O0 and it does run again. | ||||
* | 2007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-06-20 | 2 | -1/+17 |
| | | | | | * custom/gen5200.cfg: Remove junk comment. * custom/ep5200.cfg: New file. | ||||
* | 2007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-12 | 1 | -31/+0 |
| | | | | * custom/armulator.cfg: Removed. | ||||
* | 2007-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-16 | 1 | -1/+1 |
| | | | | * custom/mvme5500.cfg: Use -O2 again. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -42/+0 |
| | | | | | * Makefile.am: DMV152 obsoleted. * custom/dmv152.cfg: Removed. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 2 | -44/+0 |
| | | | | | | * Makefile.am: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants. * custom/erc32nfp.cfg, custom/leon1.cfg: Removed. | ||||
* | 2007-05-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-10 | 6 | -41/+27 |
| | | | | | | * custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/pc386.cfg, custom/sim68000.cfg, custom/ts_386ex.cfg: Clean up to use .nxe extension instead of BSP unique ones. | ||||
* | 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-09 | 6 | -13/+13 |
| | | | | | * leaf.cfg, compilers/gcc-no_bsp.cfg: Add optional manager stub for Classic API Barrier. | ||||
* | 2007-04-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-26 | 1 | -7/+0 |
| | | | | * custom/rtl22xx.cfg: Cleanup. | ||||
* | 2007-04-26 Ray Xu <xr@trasin.net> | Ralf Corsepius | 2007-04-26 | 1 | -0/+40 |
| | | | | * custom/rtl22xx.cfg: New (Initial submission). | ||||
* | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 65 | -65/+65 |
* | Use $(NM) -g -n instead of $(NM) -n. | Ralf Corsepius | 2007-01-18 | 6 | -6/+6 |
* | Use $(NM) -g -n instead of $(NM) -ng. | Ralf Corsepius | 2007-01-18 | 5 | -5/+5 |
* | Fix cvs id. | Ralf Corsepius | 2007-01-18 | 2 | -2/+2 |
* | Misc cleanups. | Ralf Corsepius | 2007-01-18 | 23 | -65/+54 |
* | Add comment on CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 3 | -3/+3 |
* | Remove obsolete comments. | Ralf Corsepius | 2007-01-18 | 2 | -6/+0 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 36 | -36/+36 |
| | | | | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg, custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg, custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg, custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg, custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 20 | -27/+27 |
* | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 2007-01-18 | 46 | -92/+46 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -3/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 5 | -7/+3 |
* | Remove CXXFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 3 | -3/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+0 |
* | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 2007-01-18 | 6 | -6/+5 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 9 | -9/+0 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 1 | -2/+1 |
| | | | | * custom/h8sim.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 13 | -18/+16 |
