path: root/make/custom/virtex.cfg (follow)
* 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-181-3/+0
| | | | | | | | | * compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg, custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg, custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate START_BASE and START_FILE.
* 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-03-111-1/+1
| | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/default.cfg, custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg, custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to explicit .exe instead of EXEEXT to get it to work.
* Make all BSPs use the same rules for invoking gcc and g++ to link an ↵Joel Sherrill2008-03-061-29/+3
| | | | application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* 2007-07-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-07-281-1/+1
| | | | * custom/virtex.cfg: Use -O2.
* added virtex configurationThomas Doerfler2007-07-041-0/+57
