* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH
simulator is just an architectural simulator and does not include
devices. Rename existing simulator BSP configurations to simsh1 and
simsh2 and add simsh4.
* custom/simsh1.cfg, custom/simsh2.cfg: New files.
* custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/gensh4.cfg: Remove START_HW_INIT.
* custom/simsh4.cfg: Remove START_HW_INIT, RTEMS_CPU_MODEL=sh7750.
* custom/gensh4.cfg: Remove HZ.
* custom/simsh4.cfg: Remove HZ.
* custom/gensh4.cfg, custom/simsh4.cfg: New files in support
of Hitachi SH4 BSPs of the same name. Reviewed and some
cleanup by Joel Sherrill <joel@OARcorp.com>.
