* | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1998-04-15 | 1 | -4/+0 |
| | | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | ||||
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 1 | -5/+0 |
* | Changed RTEMS cpu to hppa1.1. | Joel Sherrill | 1998-03-24 | 1 | -2/+1 |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -0/+1 |
| | | | | the CPU family name constants. | ||||
* | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1998-01-20 | 1 | -0/+145 |
