cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
* RTEMS_CPU for score603e should be "powerpc" instead of "ppc" (Should
not have any side-effects, because RTEMS_CPU in make/custom/*.cfg
already is overridden in make/target.cfg.in)
* Use $(PACKHEX) instead of $(PROJECT_TOOLS)/packhex
