custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
* RTEMS_CPU for score603e should be "powerpc" instead of "ppc" (Should
not have any side-effects, because RTEMS_CPU in make/custom/*.cfg
already is overridden in make/target.cfg.in)
* Use $(PACKHEX) instead of $(PROJECT_TOOLS)/packhex
