* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -11/+1 |
* | Removed need for START_BASE. | Joel Sherrill | 1999-11-22 | 1 | -3/+0 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-07-30 | 1 | -3/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The main topic is replacing the hard-coded values for HAS_MP and HAS_RDBG in custom/*.cfg with per-bsp configuration-time autoconf checks (This is the patch I had mentioned before earlier this week). CHANGES * HAS_MP removed from custom/*.cfg, replaced with configuration time autoconf check * HAS_RDBG removed from custom/*.cfg, replaced with configuration-time autoconf check * NEW: c/src/make/bsp.cfg.in, takes configuration-time checked per-bsp values (i.e. HAS_MP, HAS_RDBG), gets installed as $(prefix)/<bsp>/make/bsp.cfg * NEW: default.cfg includes bsp.cfg - this change is backward compatible. * IMPORT_SRC: apply VPATH instead for ts_386ex/i386ex subdirectory Makefile.ins * HACK: a bug in acpolish mis-handles addtions to makefile variables which are enclosed in gmake conditionals: c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in * Apply inline_dir, HAS_MP and HAS_RDBG for avoiding configuration of unneeded subdirectories in various configure.in files. * Several minor changes in Makefile.ins and configure.ins, wrt. to the order of including *.cfg and defining Makefile variables APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-4.diff ./autogen | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-04-12 | 1 | -2/+0 |
| | | | | | | | | Installing of bsp_specs for aliased bsps is broken. Instead of installing RTEMS_BSP_FAMILY/bsp_specs, RTEMS_BSP/bsp_specs was tried to be installed. The patch below should fix this problem (tested with mips64orion p4600 and p4650). | ||||
* | Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules. | Joel Sherrill | 1999-03-08 | 1 | -1/+2 |
* | ./clock/Makefile.in,v | Joel Sherrill | 1999-02-18 | 1 | -0/+111 |
./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v ./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v |
