2009-10-15 | Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | Ralf Corsepius | 1 | -14/+0 | |
2007-01-18 | Misc cleanups. | Ralf Corsepius | 1 | -5/+3 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -2/+2 | |
2005-01-20 | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+3 | |
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg, custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg, custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg, custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for gcc 4.x. Hopefully they are still OK for gcc 3.3.5. | |||||
2002-07-24 | 2002-07-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+4 | |
* custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg: Updated to use gcc 3.1 arguments. | |||||
2000-08-25 | 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float | |||||
2000-01-10 | Added pc486 and pc586 as aliases of pc386 with proper cpu flags. | Joel Sherrill | 1 | -0/+11 | |
