* | Changed invocation of bin2boot to match gcc 2.8 rule. | Joel Sherrill | 1998-05-27 | 1 | -1/+1 |
* | Modified objcopy to remove extra sections. | Joel Sherrill | 1998-05-04 | 1 | -3/+6 |
| | | | | Modified gcc 2.8 style link rule to provide start address correctly. | ||||
* | Modified objcopy invocation to ignore more sections. | Joel Sherrill | 1998-04-30 | 1 | -3/+7 |
* | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>. | Joel Sherrill | 1998-04-27 | 1 | -17/+31 |
* | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1998-04-15 | 1 | -4/+0 |
| | | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | ||||
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 1 | -5/+0 |
* | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1998-01-20 | 1 | -0/+96 |
