* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/pc386.cfg (make-exe): Removed commented out lines that
were displayed in build longs.
* custom/pc386.cfg: make-exe rule would write into
$(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE)
is generally not writeable after the BSP is installed and you do not
want every application installed there by default. Reported by
Eric Norum <eric.norum@usask.ca>.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
Erwin Rol <erwin@muffin.org>.
in the previous commits.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
exceptions and makes debug stack traces impossible.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
I had trouble merging his original patch and this corrected a reject.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
Modified gcc 2.8 style link rule to provide start address correctly.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
