2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -30/+0 | |
* custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||||
2008-03-11 | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg, custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg, custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to explicit .exe instead of EXEEXT to get it to work. | |||||
2008-03-06 | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 1 | -16/+4 | |
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | |||||
2007-01-18 | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 1 | -1/+1 | |
2007-01-18 | Misc cleanups. | Ralf Corsepius | 1 | -3/+2 | |
2007-01-18 | Add comment on CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 1 | -2/+1 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -1/+1 | |
2007-01-18 | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 1 | -2/+1 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -3/+1 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -3/+3 | |
2006-08-09 | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 1 | -0/+47 | |
* Makefile.am: New port to Altera NIOS II. * custom/nios2_iss.cfg: New file. |
