* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/mvme5500.cfg: Fix typo.
* custom/mvme5500.cfg: Add compiler arguments sine without them, the
BSP has issues.
* custom/mvme5500.cfg: Use -O2 again.
* leaf.cfg, compilers/gcc-no_bsp.cfg: Add optional manager stub
for Classic API Barrier.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
PR 1150/bsps
* custom/mvme5500.cfg: This is a follow-up of the PR846 due to the fact
that gcc (4.0.2) implicitely uses the vector engine for optimization;
-mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec is better.
* custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use
-mcpu=750 instead.
* custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI.
* custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V.
Remove -Wa,-m7450.
