* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -2/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 1 | -7/+1 |
* | 2006-09-08 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2006-09-08 | 1 | -1/+1 |
| | | | | | | | PR 1150/bsps * custom/mvme5500.cfg: This is a follow-up of the PR846 due to the fact that gcc (4.0.2) implicitely uses the vector engine for optimization; -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec is better. | ||||
* | 2005-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-11-04 | 1 | -1/+1 |
| | | | | | * custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use -mcpu=750 instead. | ||||
* | Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | Ralf Corsepius | 2005-05-27 | 1 | -1/+0 |
* | 2005-03-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-03-03 | 1 | -6/+2 |
| | | | | | | * custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI. * custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V. Remove -Wa,-m7450. | ||||
* | Add -Wa,-m7450 to CPU_CFLAGS until gcc/gas get their acts together. | Eric Norum | 2004-10-27 | 1 | -1/+1 |
* | Add MVME5500 BSP. | Eric Norum | 2004-10-20 | 1 | -0/+48 |
