* | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-18 | 1 | -13/+3 |
| | | | | | PR 1314/bsps * custom/mvme3100.cfg: Remove old stuff. | ||||
* | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-11 | 1 | -1/+1 |
| | | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/default.cfg, custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg, custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to explicit .exe instead of EXEEXT to get it to work. | ||||
* | 2008-03-06 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-03-07 | 1 | -1/+1 |
| | | | | * custom/mvme3100.cfg: Fixed typo, 'endef' not 'endif'. | ||||
* | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 2008-03-06 | 1 | -15/+4 |
| | | | | application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | ||||
* | 2008-02-11 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-02-11 | 1 | -5/+1 |
| | | | | | * custom/mvme3100.cfg: Removed CFLAGS_PROFILE_V; added '-g' to CFLAGS_DEBUG_V. | ||||
* | 2008-01-09 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2008-01-09 | 1 | -0/+8 |
| | | | | * custom/mvme3100.cfg: Add make-cxx-exe rule. | ||||
* | 2007-12-14 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-12-14 | 1 | -0/+44 |
* custom/mvme3100.cfg: Added; new BSP. |
