path: root/make/custom/mvme2307.cfg (follow)
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-13/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/eth_comm.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS. * custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS. * custom/mbx8xx.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS. Remove obsolete comments. * custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS. Remove obsolete comments. * custom/mpc8260ads.cfg: Remove make-target-options. Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS. Remove obsolete comments. * custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-211-13/+0
| | | | | * custom/mvme2307.cfg: Reflect changes to motorola_powerpc/configure.ac. * custom/mcp750.cfg: Ditto.
* 2001-11-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-141-8/+0
| | | | | | | * custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg: These are new exception processing model BSPs and thus do not need to define PPC_USE_SPRG.
* 2001-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-141-15/+11
| | | | | | * custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options. * custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options, re-adopt mcp750.cfg's make-exe.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-191-6/+0
| | | | | | | | | | | | | | | | | custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options. custom/FreeBSD-posix.cfg: Remove make-target-options. custom/HPUX9-posix.cfg: Dito. custom/Linux-posix.cfg: Dito. custom/Solaris-posix.cfg: Dito. custom/arm_bare_bsp.cfg: Dito. custom/armulator.cfg: Dito. custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/i386ex.cfg: Remove make-target-options. custom/i960sim.cfg: Remove make-target-options. custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/rxgen960.cfg: Remove make-target-options, cleanup comments. custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/vegaplus.cfg: Remove make-target-options.
* Patch rtems-rc-20000731-2-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-011-1/+1
| | | | | | | | | | | | | | that does the following: Changes: Remove $(SED) and $(CP) from make/custom/*.cfg Motivation: * autoconf and automake presuppose sed and cp to be present. * make/host.cfg.in already contains SED = sed hard-coded into it for a long time. * Elimination of make-variables * Eliminate make/*.cfg files or at least reduce their complexity :)
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-5/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Removed NDEBUG as a per BSP option.Joel Sherrill2000-07-131-5/+0
* Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-121-4/+0
| | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-29/+33
* Renaming mcp750 to motorola_shared since that is the basis for bothJoel Sherrill2000-01-071-2/+2
| | | | | the mvme2307 and mcp750 BSPs. In addition, it can support many Motorola PowerPC based VME and PCI boards.
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-021-1/+1
| | | | | As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
* Removed HAS_MP=no and commented out HAS_NETWORKING=no.Joel Sherrill1999-11-011-8/+0
* Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>.Joel Sherrill1999-10-041-0/+112
No modifications made.
