path: root/make/custom/mvme167.cfg (follow)
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-4/+0
* Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules.Joel Sherrill1999-03-081-1/+1
* Patch from Charles Gauthier <Charles.Gauthier@@iit.nrc.ca> to addressJoel Sherrill1999-02-241-3/+19
| | | | | | | | | | | | | | | | | | | | | | | | | | | | FP issues on this target: The default variants of libc, libm and libgcc assume that a 68881 coprocessor is present. Without the FPSP, any floating point operation, including printf() with a "%f" format specifier, is likely to cause an unimplemented instruction exception. The FPSP works with the default variants of libc, libm and libgcc. It does not work in conjunction with the msoft-float variants. The paranoia test goes into an infinite loop at milestone 40. I am guessing that floor() is returning an incorrect value. The msoft-float variants of libc, libm and libgcc appear to do floating point I/O properly. They only failed in paranoia. Offhand, I can't think of why they would conflict with the FPSP, so I think that there is something wrong with the msoft-float code. It might be my installation. Given my experiences, I decided to install the FPSP in bsp_start(), and to link against the default variants of libc, libm and libgcc. This causes the executables to increase in size by about 60 KB. The README file and the mvme167.cfg specify how to remove the FPSP, and how to link against the msoft-float variants of the libraries. This is not what Eric Norum had done: on my host, his gen68360_040 port links RTEMS code with the msoft-float variants of libc and libm, and the default variant of libgcc. In this configuration, the output of printf() with "%f" is garbage on my target.
* MVME167 BSP submitted by Charles Gauthier <Charles.Gauthier@iit.nrc.ca>.Joel Sherrill1999-02-181-0/+74
