PR 1371/bsps
* custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg: Change CCFLAGS to use the
-mcpu= option for Coldfires now supported in GCC 4.3.0.
2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au>
* custom/mcf52235.cfg: New.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/mvme167.cfg: Remove PRINTK_MINOR, CONSOLE_MINOR (move to
the BSP's configure-script).
Remove BSP_CPPFLAGS (Obsolete).
* custom/armulator.cfg: Remove make-target-options.
* custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE
(now in erc32/configure.ac).
* custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS,
SIMSPARC_FAST_IDLE (now in leon2/configure.ac).
Remove CONSOLE_USE_POLLED (Unused).
* custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE,
CD2401_USE_TERMIOS (now in mvme167/configure.ac).
* custom/mvme162.cfg: Remove references to mvme162lx.
Abandon gcc272. Remove make-target-options.
* custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* custom/mbx8xx.cfg, custom/mvme167.cfg: Rewrote use of strip command
to avoid using the apparently broken or deprecated -o argument.
* custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include
compiler arguments that specify CPU model options.
* mvme167.cfg: Add specification of printk port, console port
and serial I/O mode. Arrange for the stripped executable to
be copied up the build tree.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
significant things:
and PowerPC
same code base.
FP issues on this target:
The default variants of libc, libm and libgcc assume that a 68881
coprocessor is present. Without the FPSP, any floating point operation,
including printf() with a "%f" format specifier, is likely to cause an
unimplemented instruction exception.
The FPSP works with the default variants of libc, libm and libgcc. It does not
work in conjunction with the msoft-float variants. The paranoia test goes into
an infinite loop at milestone 40. I am guessing that floor() is returning an
incorrect value.
The msoft-float variants of libc, libm and libgcc appear to do floating point
I/O properly. They only failed in paranoia. Offhand, I can't think of why they
would conflict with the FPSP, so I think that there is something wrong with the
msoft-float code. It might be my installation.
Given my experiences, I decided to install the FPSP in bsp_start(), and to link
against the default variants of libc, libm and libgcc. This causes the
executables to increase in size by about 60 KB. The README file and the
mvme167.cfg specify how to remove the FPSP, and how to link against the
msoft-float variants of the libraries. This is not what Eric Norum had done: on
my host, his gen68360_040 port links RTEMS code with the msoft-float variants
of libc and libm, and the default variant of libgcc. In this configuration, the
output of printf() with "%f" is garbage on my target.
