to update the mvme167 BSP and account for the fact that RAM base
does not have to start at 0.
The patch contains:
* build variants support
* Reworked make-exe custom/*.cfg for all targets (Should be
self-explanatory, may still be incomplete)
* Several fixes to custom/*.cfgs related to setting debug flags
* Fixes to some bsp_specs for BSPs which apparently have never been
build with debugging before ;)
* pc386.cfg fix attempts (cf. my mail from earlier today)
* Updated ampolish (No need to run it, the patch contains the result
from having applied it)
Known bugs/deficiencies related to this work:
* "make [clean|distclean]" support is still incomplete (e.g. "make
clean" does not delete all Depends-o-*)
* Completely untested for linux/posix and hppa.
* Build failures of i960 BSPs (make VARIANT=DEBUG) - I guess, they are
not related to this patch.
* Successfully tested for all sh, sparc, i386, ppc, m68k BSPs (make
VARIANT=DEBUG)
* make VARIANT=PROFILE not supported by all BSPs (I don't care :)
* make VARIANT=DEBUG failures below tests/ for some BSPs (e.g. gensh1),
because of the tests's binaries being too large to fit into the target
memory layout.
FP issues on this target:
The default variants of libc, libm and libgcc assume that a 68881
coprocessor is present. Without the FPSP, any floating point operation,
including printf() with a "%f" format specifier, is likely to cause an
unimplemented instruction exception.
The FPSP works with the default variants of libc, libm and libgcc. It does not
work in conjunction with the msoft-float variants. The paranoia test goes into
an infinite loop at milestone 40. I am guessing that floor() is returning an
incorrect value.
The msoft-float variants of libc, libm and libgcc appear to do floating point
I/O properly. They only failed in paranoia. Offhand, I can't think of why they
would conflict with the FPSP, so I think that there is something wrong with the
msoft-float code. It might be my installation.
Given my experiences, I decided to install the FPSP in bsp_start(), and to link
against the default variants of libc, libm and libgcc. This causes the
executables to increase in size by about 60 KB. The README file and the
mvme167.cfg specify how to remove the FPSP, and how to link against the
msoft-float variants of the libraries. This is not what Eric Norum had done: on
my host, his gen68360_040 port links RTEMS code with the msoft-float variants
of libc and libm, and the default variant of libgcc. In this configuration, the
output of printf() with "%f" is garbage on my target.
