* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg: Change CCFLAGS to use the
-mcpu= option for Coldfires now supported in GCC 4.3.0.
2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au>
* custom/mcf52235.cfg: New.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
that does the following:
Remove $(SED) and $(CP) from make/custom/*.cfg
Motivation:
* autoconf and automake presuppose sed and cp to be present.
* make/host.cfg.in already contains SED = sed hard-coded into it for
a long time.
* Elimination of make-variables
* Eliminate make/*.cfg files or at least reduce their complexity :)
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
