* | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 2007-01-18 | 1 | -2/+1 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 1 | -1/+1 |
* | Use .srec for files containing SRECs. | Ralf Corsepius | 2005-11-22 | 1 | -4/+4 |
* | 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-04 | 1 | -1/+1 |
| | | | | | PR 553/bsps * custom/mrm332.cfg: Comment out objdump. | ||||
* | 2004-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-20 | 1 | -1/+4 |
| | | | | | | PR 553/bsps * custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a comment. | ||||
* | 2003-01-20 Duane Gustavus <duane@unt.edu> | Joel Sherrill | 2003-01-20 | 1 | -1/+3 |
| | | | | * custom/m2m332.cfg: Fix path to linkcmds_ROM. | ||||
* | 2002-08-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-06 | 1 | -1/+1 |
| | | | | | * custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/mrm332.cfg: Use more proper CPU models so libcpu knows more. | ||||
* | 2002-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -13/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/cvme961.cfg: Remove GCC272 support. * custom/dmv152.cfg: Remove GCC272 support. * custom/efi332.cfg: Remove GCC272 support. * custom/efi68k.cfg: Remove GCC272 support. * custom/eth_comm.cfg: Remove GCC272 support. * custom/gen405.cfg: Remove GCC272 support. * custom/gen68302.cfg: Remove GCC272 support. * custom/gen68340.cfg: Remove GCC272 support. * custom/gen68360.cfg: Remove GCC272 support. * custom/genmongoosev.cfg: Remove GCC272 support. * custom/helas403.cfg: Remove GCC272 support. * custom/i386ex.cfg: Remove GCC272 support. * custom/i960sim.cfg: Remove GCC272 support. * custom/idp.cfg: Remove GCC272 support. * custom/leon2.cfg: Remove GCC272 support. * custom/mbx8xx.cfg: Remove GCC272 support. * custom/mcf5206elite.cfg: Remove GCC272 support. * custom/mpc8260ads.cfg: Remove GCC272 support. * custom/mrm332.cfg: Remove GCC272 support. * custom/mvme136.cfg: Remove GCC272 support. * custom/mvme147.cfg: Remove GCC272 support. * custom/mvme167.cfg: Remove GCC272 support. * custom/ods68302.cfg: Remove GCC272 support. * custom/p4000.cfg: Remove GCC272 support. * custom/p4600.cfg: Remove GCC272 support. * custom/p4650.cfg: Remove GCC272 support. * custom/pc386.cfg: Remove GCC272 support. * custom/portsw.cfg: Remove GCC272 support. * custom/psim.cfg: Remove GCC272 support. * custom/rxgen960.cfg: Remove GCC272 support. * custom/score603e.cfg: Remove GCC272 support. * custom/sim68000.cfg: Remove GCC272 support. * custom/simhppa.cfg: Remove GCC272 support. * custom/simsh4.cfg: Remove GCC272 support. * custom/ts_386ex.cfg: Remove GCC272 support. | ||||
* | 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-12-07 | 1 | -17/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | * custom/bare.cfg: Remove make-target-options. * custom/c4xsim.cfg: Ditto. * custom/cvme961.cfg: Ditto. * custom/efi68k.cfg: Ditto. * custom/gen68302.cfg: Ditto. * custom/gen68340.cfg: Ditto. * custom/genmongoosev.cfg: Ditto. * custom/gensh4.cfg: Remove make-target-options, remove GCC272 make-exe, remove empty lines. * custom/h8sim.cfg: Remove make-target-options. * custom/mcf5206elite.cfg: Ditto. * custom/mrm332.cfg: Ditto. * custom/mvme147.cfg: Ditto. * custom/ods68302.cfg: Ditto. * custom/p4000.cfg: Ditto. * custom/p4600.cfg: Ditto. * custom/p4650.cfg: Ditto. * custom/pc386.cfg: Ditto. * custom/portsw.cfg: Ditto. * custom/simsh4.cfg: Ditto. | ||||
* | 2001-05-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-05-25 | 1 | -2/+2 |
| | | | | * custom/mrm332.cfg: Switched $(SED) to sed. | ||||
* | 2000-05-25 Matt Cross <profesor@gweep.net> | Joel Sherrill | 2001-05-25 | 1 | -0/+93 |
* New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files. |
