* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg: Change CCFLAGS to use the
-mcpu= option for Coldfires now supported in GCC 4.3.0.
2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au>
* custom/mcf52235.cfg: New.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/mcf5235.cfg, custom/mrm332.cfg, custom/pc386.cfg: Split
the make-exe and make-cxx-exe into bsp-link-c, bsp-link-cxx and
bsp-post-link make macros. This allow external autotools support.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
PR 553/bsps
* custom/mrm332.cfg: Comment out objdump.
PR 553/bsps
* custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a
comment.
* custom/m2m332.cfg: Fix path to linkcmds_ROM.
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg,
custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/mrm332.cfg: Switched $(SED) to sed.
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
