application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI.
* custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V.
Remove -Wa,-m7450.
* eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg,
mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
Remove obsolete comments.
* custom/eth_comm.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS.
* custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS.
* custom/mbx8xx.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS.
* custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS.
* custom/mpc8260ads.cfg: Remove make-target-options.
Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS.
* custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG;
* custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE,
DATA_CACHE_ENABLE.
* custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac.
* custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac.
* custom/mbx860_005b.cfg: Ditto.
* custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg:
These are new exception processing model BSPs and thus do not
need to define PPC_USE_SPRG.
* custom/mpc8260ads.cfg: New file.
* leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V.
* compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags,
remove unused flags, remove -ansi from CPP.
* custom/eth_comm.cfg: Remove CPU_DEFINES.
* custom/sim68000.cfg: Remove CPU_DEFINES.
* custom/eth_comm.cfg: Switch the eth_comm BSP to use the
"new exception processing model."
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
significant things:
and PowerPC
same code base.
based board.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
