* custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the
use the "new exception processing model."
* custom/mbx860_005b.cfg (make-target-options): Add lines to
define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings
may be incorrect but the BSP now compiles.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
enabled now at configure time.
cpuopts.h.
to disabled.
problems at runtime.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
