path: root/make/custom/leon2.cfg (follow)
* Cosmetics.Ralf Corsepius2007-01-181-1/+1
* Cleanup.Ralf Corsepius2006-11-301-2/+1
* Merger from rtems-4-6-branch.Ralf Corsepius2006-01-091-8/+4
* 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-031-13/+0
| | | | | | * custom/erc32nfp.cfg: Remove CPU_U32_FIX. * custom/erc32.cfg: Ditto. * custom/leon2.cfg: Ditto.
* 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-291-4/+0
| | | | | | * custom/erc32.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/erc32nfp.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/leon2.cfg: Remove NO_TABLE_MOVE.
* 2002-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-14/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/cvme961.cfg: Remove GCC272 support. * custom/dmv152.cfg: Remove GCC272 support. * custom/efi332.cfg: Remove GCC272 support. * custom/efi68k.cfg: Remove GCC272 support. * custom/eth_comm.cfg: Remove GCC272 support. * custom/gen405.cfg: Remove GCC272 support. * custom/gen68302.cfg: Remove GCC272 support. * custom/gen68340.cfg: Remove GCC272 support. * custom/gen68360.cfg: Remove GCC272 support. * custom/genmongoosev.cfg: Remove GCC272 support. * custom/helas403.cfg: Remove GCC272 support. * custom/i386ex.cfg: Remove GCC272 support. * custom/i960sim.cfg: Remove GCC272 support. * custom/idp.cfg: Remove GCC272 support. * custom/leon2.cfg: Remove GCC272 support. * custom/mbx8xx.cfg: Remove GCC272 support. * custom/mcf5206elite.cfg: Remove GCC272 support. * custom/mpc8260ads.cfg: Remove GCC272 support. * custom/mrm332.cfg: Remove GCC272 support. * custom/mvme136.cfg: Remove GCC272 support. * custom/mvme147.cfg: Remove GCC272 support. * custom/mvme167.cfg: Remove GCC272 support. * custom/ods68302.cfg: Remove GCC272 support. * custom/p4000.cfg: Remove GCC272 support. * custom/p4600.cfg: Remove GCC272 support. * custom/p4650.cfg: Remove GCC272 support. * custom/pc386.cfg: Remove GCC272 support. * custom/portsw.cfg: Remove GCC272 support. * custom/psim.cfg: Remove GCC272 support. * custom/rxgen960.cfg: Remove GCC272 support. * custom/score603e.cfg: Remove GCC272 support. * custom/sim68000.cfg: Remove GCC272 support. * custom/simhppa.cfg: Remove GCC272 support. * custom/simsh4.cfg: Remove GCC272 support. * custom/ts_386ex.cfg: Remove GCC272 support.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-181-17/+0
| | | | | | | | | | | | | | * custom/armulator.cfg: Remove make-target-options. * custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in erc32/configure.ac). * custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in leon2/configure.ac). Remove CONSOLE_USE_POLLED (Unused). * custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE, CD2401_USE_TERMIOS (now in mvme167/configure.ac). * custom/mvme162.cfg: Remove references to mvme162lx. Abandon gcc272. Remove make-target-options. * custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-151-13/+0
| | | | | * custom/leon2.cfg: Removed defines that are now generated in a non-BSP specific manner.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-131-0/+101
* custom/Makefile.am: Modified to reflect addition of files. * custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant. * custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
