* custom/jmr3904.cfg: arm_bare_bsp obsoleted.
* custom/arm_bare_bsp.cfg: Removed.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg,
custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg,
custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg,
custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for
gcc 4.x. Hopefully they are still OK for gcc 3.3.5.
* custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch
to gcc 3.1 arguments.
* custom/jmr3904.cfg, custom/p4650.cfg: Add comments for gcc 3.1
compatable arguments.
* custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS.
* custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272
support.
* custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* custom/efi332.cfg: Remove make-target-options.
* custom/idp.cfg: Ditto.
* custom/jmr3904.cfg: Ditto.
* custom/jmr3904.cfg: Turn optimization back up to -O2.
* custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually
a mips1. gcc translates -m3900 into that.
* custom/jmr3904.cfg: Fix incorrect reference to i960.
* custom/Makefile.am: Updated to add jmr3904.cfg
* custom/jmr3904.cfg: New file.
