* custom/efi332.cfg: Remove make-target-options.
* custom/idp.cfg: Ditto.
* custom/jmr3904.cfg: Ditto.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
that does the following:
Remove $(SED) and $(CP) from make/custom/*.cfg
Motivation:
* autoconf and automake presuppose sed and cp to be present.
* make/host.cfg.in already contains SED = sed hard-coded into it for
a long time.
* Elimination of make-variables
* Eliminate make/*.cfg files or at least reduce their complexity :)
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
