* custom/h8sim.cfg: i960 obsoleted.
* custom/cvme961.cfg, custom/i960sim.cfg, custom/rxgen960.cfg: Removed.
custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
by gdb 5.0's i960 simulator) is enough to run hello world.
