* | Changed default target architecture name | Joel Sherrill | 1998-04-30 | 1 | -1/+1 |
* | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1998-04-15 | 1 | -4/+0 |
| | | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | ||||
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 1 | -5/+0 |
* | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1998-01-20 | 1 | -0/+121 |
