* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg,
custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
Geoffroy Montel <g_montel@yahoo.com>.
