path: root/make/custom/gen68340.cfg (unfollow)
2001-12-072001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+0
* custom/bare.cfg: Remove make-target-options. * custom/c4xsim.cfg: Ditto. * custom/cvme961.cfg: Ditto. * custom/efi68k.cfg: Ditto. * custom/gen68302.cfg: Ditto. * custom/gen68340.cfg: Ditto. * custom/genmongoosev.cfg: Ditto. * custom/gensh4.cfg: Remove make-target-options, remove GCC272 make-exe, remove empty lines. * custom/h8sim.cfg: Remove make-target-options. * custom/mcf5206elite.cfg: Ditto. * custom/mrm332.cfg: Ditto. * custom/mvme147.cfg: Ditto. * custom/ods68302.cfg: Ditto. * custom/p4000.cfg: Ditto. * custom/p4600.cfg: Ditto. * custom/p4650.cfg: Ditto. * custom/pc386.cfg: Ditto. * custom/portsw.cfg: Ditto. * custom/simsh4.cfg: Ditto.
2000-09-122000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress. * custom/gen68302.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68340.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68360.cfg: Comment out LIBC_LIB[C|M]. * custom/idp.cfg: Comment out LIBC_LIB[C|M]. * custom/mvme162.cfg: Comment out LIBC_LIB[C|M]. * custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
2000-07-13Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+0
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
2000-07-13Removed NDEBUG as a per BSP option.Joel Sherrill1-5/+0
2000-07-12Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-4/+0
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-18/+18
1999-11-22Removed need for START_BASE.Joel Sherrill1-3/+0
1999-11-05Eliminated references to stack checker related #defines.Joel Sherrill1-9/+0
1999-03-08Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules.Joel Sherrill1-2/+2
1998-10-15Removed unnecessary settings.Joel Sherrill1-6/+0
1998-07-01Initial submission of gen68340 BSP (should run on a 68349) fromJoel Sherrill1-22/+30
Geoffroy Montel <g_montel@yahoo.com>.
1998-06-27Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1-1/+2
made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
1998-06-25Added definition of RTEMS__mcpu32p__ per patch from Robin Kirkham.Joel Sherrill1-0/+1
1998-04-15Stack checker now enabled via initial set of user extensions. ThisJoel Sherrill1-4/+0
eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined.
1998-04-06Purged references to STACK_CHECKER_REPORT_USAGEJoel Sherrill1-5/+0
1998-04-06Changed CPU model to mcpu32.Joel Sherrill1-1/+1
1998-03-23Update from Eric Norum:Joel Sherrill1-12/+3
Here are some patches to the gen68360 BSP. The improvements include: Boot prom run-time selection of DRAM size (1/4/16 Mbytes) Full 32-bit ethernet address obtained from boot prom. Updated README.
1998-03-20Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1-11/+2
I've included a version of make/custom/gen68360.cfg that works with this. Note that I've removed the option of using `-m68020 -msoft-float -mno-bitfield' as an alternative to using `-mcpu32'. The alternative won't work with the new system (since it predefines __mc68020__ and not __mcpu32__), and didn't really work before anyway (since the newlib that gets linked was built with `-m68020 -msoft-float' and so could contain bitfield operators).
1998-02-19Patch from Eric Norum:Joel Sherrill1-5/+0
While trying to work through this problem I decided that the build-time selection of the console I/O operation (polling or interrupt) was too clumsy. Here's a patch that allows run-time (actually init-time) selection of the console I/O mode. It also shows the need for another `flags' or `options' field in the rtems_driver_address_table structure...
1998-01-20Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1-0/+124
