path: root/make/custom/gen68340.cfg (follow)
* Patch rtems-rc-4.5.0-6-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-031-18/+18
| | | | | | | | | | | | | | | | | | | | | | | | | | | | The patch contains: * build variants support * Reworked make-exe custom/*.cfg for all targets (Should be self-explanatory, may still be incomplete) * Several fixes to custom/*.cfgs related to setting debug flags * Fixes to some bsp_specs for BSPs which apparently have never been build with debugging before ;) * pc386.cfg fix attempts (cf. my mail from earlier today) * Updated ampolish (No need to run it, the patch contains the result from having applied it) Known bugs/deficiencies related to this work: * "make [clean|distclean]" support is still incomplete (e.g. "make clean" does not delete all Depends-o-*) * Completely untested for linux/posix and hppa. * Build failures of i960 BSPs (make VARIANT=DEBUG) - I guess, they are not related to this patch. * Successfully tested for all sh, sparc, i386, ppc, m68k BSPs (make VARIANT=DEBUG) * make VARIANT=PROFILE not supported by all BSPs (I don't care :) * make VARIANT=DEBUG failures below tests/ for some BSPs (e.g. gensh1), because of the tests's binaries being too large to fit into the target memory layout.
* Removed need for START_BASE.Joel Sherrill1999-11-221-3/+0
* Eliminated references to stack checker related #defines.Joel Sherrill1999-11-051-9/+0
* Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules.Joel Sherrill1999-03-081-2/+2
* Removed unnecessary settings.Joel Sherrill1998-10-151-6/+0
* Initial submission of gen68340 BSP (should run on a 68349) fromJoel Sherrill1998-07-011-0/+102
Geoffroy Montel <g_montel@yahoo.com>.
