2008-03-11 | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg, custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg, custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to explicit .exe instead of EXEEXT to get it to work. | |||||
2008-03-06 | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 1 | -22/+4 | |
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | |||||
2007-05-10 | 2007-05-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -10/+10 | |
* custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/pc386.cfg, custom/sim68000.cfg, custom/ts_386ex.cfg: Clean up to use .nxe extension instead of BSP unique ones. | |||||
2007-01-18 | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 1 | -1/+1 | |
2007-01-18 | Remove CXXFLAGS_OPTIMIZE_V. | Ralf Corsepius | 1 | -1/+0 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -2/+2 | |
2007-01-18 | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 1 | -1/+1 | |
2006-11-30 | Cleanup. | Ralf Corsepius | 1 | -8/+1 | |
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -10/+10 | |
* custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj. | |||||
2005-09-18 | 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -6/+2 | |
* custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus). | |||||
2005-06-17 | 2005-06-17 Markku Puro <markku.puro@kopteri.net> | Joel Sherrill | 1 | -0/+60 | |
* Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file. |
