path: root/make/custom/gba.cfg (follow)
* 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-03-111-1/+1
| | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/default.cfg, custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg, custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to explicit .exe instead of EXEEXT to get it to work.
* Make all BSPs use the same rules for invoking gcc and g++ to link an ↵Joel Sherrill2008-03-061-22/+4
| | | | application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* 2007-05-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-101-10/+10
| | | | | | * custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/pc386.cfg, custom/sim68000.cfg, custom/ts_386ex.cfg: Clean up to use .nxe extension instead of BSP unique ones.
* Add -g to CFLAGS_OPTIMIZE_V.Ralf Corsepius2007-01-181-1/+1
* Remove CXXFLAGS_OPTIMIZE_V.Ralf Corsepius2007-01-181-1/+0
* Cosmetics.Ralf Corsepius2007-01-181-2/+2
* CFLAGS_OPTIMIZE_V = -O2.Ralf Corsepius2007-01-181-1/+1
* Cleanup.Ralf Corsepius2006-11-301-8/+1
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-10/+10
| | | | * custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj.
* 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-181-6/+2
| | | | | * custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus).
* 2005-06-17 Markku Puro <markku.puro@kopteri.net>Joel Sherrill2005-06-171-0/+60
* Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file.
