* | Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-12 | 1 | -4/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime. | ||||
* | Moved PPC_VECTOR_FILE_BASE to targopts.h | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 1 | -2/+31 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -3/+2 |
* | Removed need for START_BASE. | Joel Sherrill | 1999-11-22 | 1 | -3/+0 |
* | Eliminated references to stack checker related #defines. | Joel Sherrill | 1999-11-05 | 1 | -9/+0 |
* | Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules. | Joel Sherrill | 1999-03-08 | 1 | -1/+1 |
* | Jay Monkman <jmonkman@frasca.com> submitted the eth_comm BSP for a PPC860 | Joel Sherrill | 1999-02-17 | 1 | -0/+84 |
based board. |
