1998-04-15 | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1 | -4/+0 | |
eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | |||||
1998-04-06 | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1 | -5/+0 | |
1998-02-18 | Went back to polled console. | Joel Sherrill | 1 | -1/+1 | |
1998-02-04 | Cleaned up the definition of CONSOLE_USE_POLLED and CONSOLE_USE_INTERRUPTS. | Joel Sherrill | 1 | -9/+9 | |
1998-01-20 | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1 | -0/+110 | |
