I discovered that when specifying -m68000 and -msoft-float to gcc 2.95.2,
it decides that the proper multilib variant is the default one which is
compiled for the m68020 and hardware floating point. This appears to be
because there is no 68000/soft-float library variant. This problem
applies to all m68000 class CPUs options including -m68302.
The patch contains:
* build variants support
* Reworked make-exe custom/*.cfg for all targets (Should be
self-explanatory, may still be incomplete)
* Several fixes to custom/*.cfgs related to setting debug flags
* Fixes to some bsp_specs for BSPs which apparently have never been
build with debugging before ;)
* pc386.cfg fix attempts (cf. my mail from earlier today)
* Updated ampolish (No need to run it, the patch contains the result
from having applied it)
Known bugs/deficiencies related to this work:
* "make [clean|distclean]" support is still incomplete (e.g. "make
clean" does not delete all Depends-o-*)
* Completely untested for linux/posix and hppa.
* Build failures of i960 BSPs (make VARIANT=DEBUG) - I guess, they are
not related to this patch.
* Successfully tested for all sh, sparc, i386, ppc, m68k BSPs (make
VARIANT=DEBUG)
* make VARIANT=PROFILE not supported by all BSPs (I don't care :)
* make VARIANT=DEBUG failures below tests/ for some BSPs (e.g. gensh1),
because of the tests's binaries being too large to fit into the target
memory layout.
that fixes numerous miscellaneous issues most related to the debug and
profile build stanzas:
Fix for the "make debug" (1) issue and an analogous issue with "make
profile" (untested).
* Fixes to mcp750.cfg (make debug, directories) (2)
* Updates/minor fixes for shgen (3)
* Updates some custom/*.cfgs to use $(LINK.c) instead of $(CC)
* Leftovers from rtems-rc-4.5.0-[0|1].diff which somehow did not make it
into cvs.
* Cleanups to the perlscripts below tools/update/
* Some unsorted minor fixes.
Footnotes/Remarks:
(1) Tested for all m68k, sh, sparc, unix and selected i386, ppc BSPs.
Known problems: I can't build the debug variant for the m68k/mvme162 and
m68k/mvme162lx (segmentation fault - signal 11 :)
(2) Tested by building the BSP, but I doubt the debug-variant is
functional. The flags used for the debug variant should be checked by
knowledgeable persons and probably at runtime #:o)
(3) I have updated shgen to use getopt_long (it should fall back to
getopt if not available), enhanced the options, cleaned up some minor
tweaks and added help2man support (rough automatic man-page generation).
Technical notes:
* make debug and make profile now work similar in target Makefile.ams as
they did in old autoconf-Makefile.ins using leaf.cfg. Unlike the rules
in leaf.cfg these Makefile.am also recurse once on themselves in
directory Makefiles before or after recursing into subdirectories, not
only in leaf-directories.
To implement this behavior, I renamed the former automake/local.am into
automake/host.am and extended local.am to provide this recursion.
I.e. host.am implements the non-self-recursive variant, while local.am
now implements the self-recursive behavior.
=> all Makefile.ams exploiting build-variants are supposed to include
local.am
=> all Makefile.ams not exploiting build-variants should include host.am
=> Rules of thumb:
- Only include one of both, either local.am or host.am into a
Makefile.am.
-Target-Makefile.ams should include local.am
-Host-Makefile.ams should include host.am (Probably, you now understand
the naming)
- There are exceptions from these rules :)
* Now, make debug|profile|all are independent of each other. However,
each of them however triggers preinstall.
* "make install" still decends into the subdirectories but does not
trigger "all|profile|debug|preinstall" in target Makefile.am anymore.
Besides triggering "install"-rules in some selected Makefile.ams, it
only packs $(PROJECT_ROOT) into a tarballs and unpacks it to $(prefix).
=> "make install" alone is not enough to install RTEMS, now use
make RTEMS_BSP=<bsps> [all] [debug] [profile]
make RTEMS_BSP=<bsp> install
I consider this to be a step back wrt. exploiting automake mechanisms,
and expect this to be reverted if we abandon building target variants in
favour of the standard convention of optionally overriding flags from
the command line (i.e. instead of "make debug", GNU standards favor
"make CFLAGS=<options> --prefix=<location>")
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
