path: root/make/custom/efi332.cfg (unfollow)
1999-11-22Removed need for START_BASE.Joel Sherrill1-3/+0
1999-08-06Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-4/+0
applied. This modified many Makefiles and custom files and makes many more settings (network, multiprocessing, etc) gnerated by autoconf.
1999-03-16Patch from John S. Gwynne <jgwynne@mrcday.com> to correct minorJoel Sherrill1-4/+1
problems that prevented the 19990302 snapshot from running on the efi332. I'm happy to report that rtems-19990302 is running on the efi332 board. I have enclosed a few minor patches below to the efi332 bsp. All patches are within that library but one. make/custom/efi332.cfg has a patch to select the right CPU_CFLAGS (at one time -m68332 was a problem... -mcpu32 or -m68332 work fine now).
1999-03-08Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules.Joel Sherrill1-1/+1
1999-02-18Part of automake VI Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-2/+2
> Adds variables to the custom/*cfg files to specify the location of > tools. The purpose is to remove hard-coded paths from the Makefiles. > > In later steps this eases moving the tools to other locations.
1998-11-19Bug report from Peter Mueller <pmueller@decrc.abb.de>:Joel Sherrill1-1/+1
I use the m68k/efi332 BSP together with a home made board. After some time of debugging I found that the m68020 CPU is used to build rtems. This is not correct, because the 68332 does not have some of the 68020 features (no separate int stack ...). It is necessary to change this to mcpu32. After a clean/make everything works fine.
1998-08-20Patches from Eric NorumJoel Sherrill1-4/+0
1998-08-20FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1-0/+4
1998-06-27Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1-1/+2
made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
1998-04-15Stack checker now enabled via initial set of user extensions. ThisJoel Sherrill1-4/+0
eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined.
1998-04-06Purged references to STACK_CHECKER_REPORT_USAGEJoel Sherrill1-7/+0
1998-01-20Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1-0/+86
