* custom/edb7312.cfg: New file.
* custom/armulator.cfg: Remove reference to PowerPC arguments.
* custom/armulator.cfg: Remove make-target-options.
* custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE
(now in erc32/configure.ac).
* custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS,
SIMSPARC_FAST_IDLE (now in leon2/configure.ac).
Remove CONSOLE_USE_POLLED (Unused).
* custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE,
CD2401_USE_TERMIOS (now in mvme167/configure.ac).
* custom/mvme162.cfg: Remove references to mvme162lx.
Abandon gcc272. Remove make-target-options.
* custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg,
custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
