* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/c3xsim.cfg, custom/c4xsim.cfg: Expand files.
* custom/bare.cfg: Remove make-target-options.
* custom/c4xsim.cfg: Ditto.
* custom/cvme961.cfg: Ditto.
* custom/efi68k.cfg: Ditto.
* custom/gen68302.cfg: Ditto.
* custom/gen68340.cfg: Ditto.
* custom/genmongoosev.cfg: Ditto.
* custom/gensh4.cfg: Remove make-target-options, remove GCC272
make-exe, remove empty lines.
* custom/h8sim.cfg: Remove make-target-options.
* custom/mcf5206elite.cfg: Ditto.
* custom/mrm332.cfg: Ditto.
* custom/mvme147.cfg: Ditto.
* custom/ods68302.cfg: Ditto.
* custom/p4000.cfg: Ditto.
* custom/p4600.cfg: Ditto.
* custom/p4650.cfg: Ditto.
* custom/pc386.cfg: Ditto.
* custom/portsw.cfg: Ditto.
* custom/simsh4.cfg: Ditto.
Removed obsolete flags from new custom files.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
