2008-09-18 | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -3/+0 | |
* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg, custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg, custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate START_BASE and START_FILE. | |||||
2008-03-06 | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 1 | -13/+0 | |
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | |||||
2007-01-18 | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 1 | -1/+1 | |
2007-01-18 | Misc cleanups. | Ralf Corsepius | 1 | -0/+3 | |
2007-01-18 | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 1 | -2/+1 | |
2007-01-18 | Cosmetics. | Ralf Corsepius | 1 | -2/+2 | |
2007-01-17 | CFLAGS_OPTIMIZE_V = -O2 | Ralf Corsepius | 1 | -2/+2 | |
2006-11-30 | Cleanup. | Ralf Corsepius | 1 | -2/+1 | |
2004-10-18 | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+26 | |
* custom/c3xsim.cfg, custom/c4xsim.cfg: Expand files. | |||||
2000-02-29 | BSP now compiles and links with CAVSL board information. This includes | Joel Sherrill | 1 | -1/+1 | |
linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included. | |||||
2000-02-22 | New port of RTEMS to TI C3x and C4x. | Joel Sherrill | 1 | -0/+12 | |
