cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
