path: root/make/custom/armulator.cfg (follow)
* 2002-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-021-2/+2
| | | | * custom/armulator.cfg: Remove reference to PowerPC arguments.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-181-2/+0
| | | | | | | | | | | | | | * custom/armulator.cfg: Remove make-target-options. * custom/erc32.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in erc32/configure.ac). * custom/leon2.cfg: Remove CONSOLE_USE_INTERRUPTS, SIMSPARC_FAST_IDLE (now in leon2/configure.ac). Remove CONSOLE_USE_POLLED (Unused). * custom/mvme167.cfg: Remove CD2401_INT_LEVEL, CD2401_IO_MODE, CD2401_USE_TERMIOS (now in mvme167/configure.ac). * custom/mvme162.cfg: Remove references to mvme162lx. Abandon gcc272. Remove make-target-options. * custom/mvme162lx.cfg: Add portions formerly in mvme162.cfg.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-191-5/+0
| | | | | | | | | | | | | | | | | custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options. custom/FreeBSD-posix.cfg: Remove make-target-options. custom/HPUX9-posix.cfg: Dito. custom/Linux-posix.cfg: Dito. custom/Solaris-posix.cfg: Dito. custom/arm_bare_bsp.cfg: Dito. custom/armulator.cfg: Dito. custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/i386ex.cfg: Remove make-target-options. custom/i960sim.cfg: Remove make-target-options. custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/rxgen960.cfg: Remove make-target-options, cleanup comments. custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/vegaplus.cfg: Remove make-target-options.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-131-6/+0
| | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg, custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* 2000-08-29 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-291-2/+2
| | | | * custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
* New bsp for simulator in gdb. Does not work yet.Joel Sherrill2000-07-311-0/+53
