path: root/make/custom/Solaris-posix.cfg (follow)
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-3/+0
| | | | it work.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-051-4/+0
| | | | | | | | | | | | | | | | | | | | As mentioned in other mails before, there is are minor inconsistencies in the posix custom/*cfg files. Linux-posix.cfg sets RTEMS_BSP=posix FreeBSD-posix.cfg sets RTEMS_BSP=posix Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets RTEMS_BSP=solaris2 1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg 2. The solaris variant of setting RTEMS_BSP is merely non-functional. The patch attached to this mail should clean up this issue. The patch was tested by building the posix bsp under i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any rtems program, however) The HPUX9 and FreeBSD configuration files were adapted in analogy to the solaris and linux configurations.
* Patches from Eric NorumJoel Sherrill1998-08-201-4/+0
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-201-0/+4
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-271-12/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
* Changed BSP name to posix.Joel Sherrill1998-06-031-0/+1
* Removed undesirable space in TARGET_ARCH assignment line.Joel Sherrill1998-05-211-9/+4
| | | | | | Cleaned up command line macro definitions. Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc.
* Some patches in place from Brian Stevens which help the Solaris portJoel Sherrill1998-05-201-7/+10
| | | | | build. It does not link successfully for him. It does not compile for me locally.
* Switched to using shared gcc-target-default.cfg.Joel Sherrill1998-05-181-3/+6
* Fixes from Ralf Corsepius:Joel Sherrill1998-04-271-1/+0
| | | | | | | | | | | | * Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg files to make/custom/posix.cfg, Removed references to stdc++ from *posix.cfg files (rtems doesn't use/need libstdc++) NOTE: Building Posix-BSPs should now work again for native compilation with gcc, i..e. linux using primary compiler and primary libc. All Posix-BSP configurations that don't use gcc as primary compiler or don't use the primary libc don't work, e.g. solaris, linux w/ egcs as secondary compiler won't be built correctly.
* Stack checker now enabled via initial set of user extensions. ThisJoel Sherrill1998-04-151-9/+0
| | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined.
* Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵Joel Sherrill1998-04-141-23/+60
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+11
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-201-0/+60
