* | Fixes from Ralf Corsepius: | Joel Sherrill | 1998-04-27 | 1 | -1/+0 |
| | | | | | | | | | | | | * Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg files to make/custom/posix.cfg, Removed references to stdc++ from *posix.cfg files (rtems doesn't use/need libstdc++) NOTE: Building Posix-BSPs should now work again for native compilation with gcc, i..e. linux using primary compiler and primary libc. All Posix-BSP configurations that don't use gcc as primary compiler or don't use the primary libc don't work, e.g. solaris, linux w/ egcs as secondary compiler won't be built correctly. | ||||
* | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1998-04-15 | 1 | -9/+0 |
| | | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | ||||
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 1 | -23/+60 |
| | | | | gcc-target-default.cfg | ||||
* | Solaris port updates from Chris Johns | Joel Sherrill | 1998-01-23 | 1 | -1/+11 |
* | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1998-01-20 | 1 | -0/+60 |
