application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/FreeBSD-posix.cfg: Remove LIBC_DEFINES (Meaningless
with FreeBSD and now unused).
* custom/Solaris-posix.cfg: Add -D__EXTENSIONS__ to CPU_CFLAGS.
* custom/Cygwin-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/FreeBSD-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/HPUX9-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/Linux-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -D_BSD_SOURCE to CPU_CFLAGS.
* custom/Solaris-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -Dsolaris2 to CPU_CFLAGS.
Remove -D__EXTENSIONS__.
* custom/Cygwin-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Linux-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Solaris-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/FreeBSD-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/HPUX9-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* custom/HPUX9-posix.cfg: Ditto.
* custom/Linux-posix.cfg: Ditto.
* custom/Cygwin-posix.cfg: Remove -DMALLOC_PROVIDED.
* custom/FreeBSD-posix.cfg: Ditto.
* custom/Solaris-posix.cfg: Ditto.
custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options.
custom/FreeBSD-posix.cfg: Remove make-target-options.
custom/HPUX9-posix.cfg: Dito.
custom/Linux-posix.cfg: Dito.
custom/Solaris-posix.cfg: Dito.
custom/arm_bare_bsp.cfg: Dito.
custom/armulator.cfg: Dito.
custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/i386ex.cfg: Remove make-target-options.
custom/i960sim.cfg: Remove make-target-options.
custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/rxgen960.cfg: Remove make-target-options, cleanup comments.
custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS.
custom/vegaplus.cfg: Remove make-target-options.
* custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg,
custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
it work.
As mentioned in other mails before, there is are minor inconsistencies in the
posix custom/*cfg files.
Linux-posix.cfg sets RTEMS_BSP=posix
FreeBSD-posix.cfg sets RTEMS_BSP=posix
Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets
RTEMS_BSP=solaris2
1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg
2. The solaris variant of setting RTEMS_BSP is merely non-functional.
The patch attached to this mail should clean up this issue.
The patch was tested by building the posix bsp under
i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any
rtems program, however) The HPUX9 and FreeBSD configuration files
were adapted in analogy to the solaris and linux configurations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
